[geos-devel] [GEOS] #913: mingw64 gcc 8.1 autotools
geos-trac at osgeo.org
Tue Aug 14 14:32:07 PDT 2018
Reporter: robe | Owner: geos-devel@…
Type: defect | Status: new
Priority: major | Milestone: 3.7.0
Component: Default | Version: master
Severity: Unassigned | Keywords:
So I upgraded my mingw64 to gcc 8.1 posix threads - seh
I think I'm actually getting further with compile under autotools now.
Before it would break on configure (so I gave up on autotools and switched
to cmake).
Now autotools seems to be getting further but failing here.
I'll submit my issue with cmake in a separate ticket.
make[4]: Leaving directory '/projects/geos/geos-3.7.0beta2/tests/unit'
make check-TESTS
make[4]: Entering directory '/projects/geos/geos-3.7.0beta2/tests/unit'
make[5]: Entering directory '/projects/geos/geos-3.7.0beta2/tests/unit'
PASS: geos_unit.exe
Testsuite summary for
# TOTAL: 1
# PASS: 1
# SKIP: 0
# XFAIL: 0
# FAIL: 0
# XPASS: 0
# ERROR: 0
make[5]: Leaving directory '/projects/geos/geos-3.7.0beta2/tests/unit'
make[3]: Leaving directory '/projects/geos/geos-3.7.0beta2/tests/unit'
Making check in perf
make[3]: Entering directory '/projects/geos/geos-3.7.0beta2/tests/perf'
Making check in operation
'/projects/geos/geos-3.7.0beta2/tests/perf/operation'
Making check in buffer
'/projects/geos/geos-3.7.0beta2/tests/perf/operation/buffer'
make[5]: Nothing to be done for 'check'.
Making check in predicate
'/projects/geos/geos-3.7.0beta2/tests/perf/operation/predicate'
make[5]: Nothing to be done for 'check-am'.
Making check in capi
'/projects/geos/geos-3.7.0beta2/tests/perf/capi'
make memleak_mp_prep.exe
x86_64-w64-mingw32-gcc -DHAVE_CONFIG_H -I. -I../../../include
-I../../../include/geos -I../../../capi -I../../../include -Wsuggest-
override -pedantic -Wall -Wno-long-long -ffloat-store
-DUSE_UNSTABLE_GEOS_CPP_API -g -O2 -MT memleak_mp_prep.o -MD -MP -MF
.deps/memleak_mp_prep.Tpo -c -o memleak_mp_prep.o memleak_mp_prep.c
cc1.exe: warning: command line option '-Wsuggest-override' is valid for
C++/ObjC++ but not for C
mv -f .deps/memleak_mp_prep.Tpo .deps/memleak_mp_prep.Po
/bin/sh ../../../libtool --tag=CC --mode=link x86_64-w64-mingw32-gcc
-Wsuggest-override -pedantic -Wall -Wno-long-long -ffloat-store
-DUSE_UNSTABLE_GEOS_CPP_API -g -O2 -o memleak_mp_prep.exe
memleak_mp_prep.o ../../../capi/libgeos_c.la ../../../capi/libgeos_c.la
libtool: link: x86_64-w64-mingw32-gcc -Wsuggest-override -pedantic -Wall
-Wno-long-long -ffloat-store -DUSE_UNSTABLE_GEOS_CPP_API -g -O2 -o
.libs/memleak_mp_prep.exe memleak_mp_prep.o
../../../capi/.libs/libgeos_c.dll.a
/projects/geos/geos-3.7.0beta2/src/.libs/libgeos.dll.a
-L/projects/geos/rel-3.7.0beta2w64gcc48/lib
make[4]: Entering directory '/projects/geos/geos-3.7.0beta2/tests/perf'
make[4]: Nothing to be done for 'check-am'.
make[4]: Leaving directory '/projects/geos/geos-3.7.0beta2/tests/perf'
make[3]: Leaving directory '/projects/geos/geos-3.7.0beta2/tests/perf'
Making check in geostest
'/projects/geos/geos-3.7.0beta2/tests/geostest'
make geostest.exe
x86_64-w64-mingw32-gcc -DHAVE_CONFIG_H -I. -I../../include
-I../../include/geos -I../../include -I../../tests/unit/tut -I../../capi
-DUSE_UNSTABLE_GEOS_CPP_API -g -O2 -MT geostest.o -MD -MP -MF
.deps/geostest.Tpo -c -o geostest.o geostest.c
mv -f .deps/geostest.Tpo .deps/geostest.Po
/bin/sh ../../libtool --tag=CC --mode=link x86_64-w64-mingw32-gcc
-DUSE_UNSTABLE_GEOS_CPP_API -g -O2 -o geostest.exe geostest.o
../../capi/libgeos_c.la -lstdc++
.libs/geostest.exe geostest.o ../../capi/.libs/libgeos_c.dll.a
/projects/geos/geos-3.7.0beta2/src/.libs/libgeos.dll.a -lstdc++
make[4]: Leaving directory '/projects/geos/geos-3.7.0beta2/tests/geostest'
make[3]: Leaving directory '/projects/geos/geos-3.7.0beta2/tests/geostest'
Making check in thread
make[3]: Entering directory '/projects/geos/geos-3.7.0beta2/tests/thread'
make threadtest.exe badthreadtest.exe
make[4]: Entering directory '/projects/geos/geos-3.7.0beta2/tests/thread'
-DUSE_UNSTABLE_GEOS_CPP_API -g -O2 -MT threadtest.o -MD -MP -MF
.deps/threadtest.Tpo -c -o threadtest.o threadtest.c
In file included from
C:/ming64gcc48/mingw64/x86_64-w64-mingw32/include/unistd.h:10,
from threadtest.c:19:
../../include/geos/io.h:19:1: error: unknown type name 'namespace'
namespace geos {
../../include/geos/io.h:19:16: error: expected '=', ',', ';', 'asm' or
'__attribute__' before '{' token
namespace geos {
In file included from ../../include/geos/io.h:48,
from
../../include/geos/io/ByteOrderDataInStream.h:30:10: fatal error: iosfwd:
No such file or directory
#include <iosfwd> // ostream, istream (if we remove inlines)
compilation terminated.
Makefile:443: recipe for target 'threadtest.o' failed
make[4]: *** [threadtest.o] Error 1
make[4]: Leaving directory '/projects/geos/geos-3.7.0beta2/tests/thread'
Makefile:555: recipe for target 'check-am' failed
make[3]: *** [check-am] Error 2
make[3]: Leaving directory '/projects/geos/geos-3.7.0beta2/tests/thread'
Makefile:429: recipe for target 'check-recursive' failed
make[2]: *** [check-recursive] Error 1
make[2]: Leaving directory '/projects/geos/geos-3.7.0beta2/tests'
Makefile:480: recipe for target 'check-recursive' failed
make[1]: *** [check-recursive] Error 1
make[1]: Leaving directory '/projects/geos/geos-3.7.0beta2'
Makefile:776: recipe for target 'check' failed
make: *** [check] Error 2
Ticket URL: <https://trac.osgeo.org/geos/ticket/913>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
