[geos-devel] [GEOS] #914: cmake compile under mingw64 gcc 8.1
GEOS geos-trac at osgeo.org
Fri Aug 17 17:51:31 PDT 2018
 Reporter:  robe                   |      Owner:  geos-devel@…
     Type:  defect                 |     Status:  new
 Priority:  major                  |  Milestone:  3.7.0
Component:  Build/Install (cmake)  |    Version:  master
 Severity:  Significant            |   Keywords:  mingw64 gcc 8.1
 CMAke compile no longer works after I upgraded my gcc from 4.8.3 to 8.1,
 though now the autoconf way at least compiles
 Your branch is up to date with 'origin/master'.
 -- The C compiler identification is GNU 8.1.0
 -- The CXX compiler identification is GNU 8.1.0
 -- Check for working C compiler: C:/ming64gcc81/mingw64/bin/gcc.exe
 -- Check for working C compiler: C:/ming64gcc81/mingw64/bin/gcc.exe --
 works
 -- Detecting C compiler ABI info
 -- Detecting C compiler ABI info - done
 -- Detecting C compile features
 -- Detecting C compile features - done
 -- Check for working CXX compiler: C:/ming64gcc81/mingw64/bin/g++.exe
 -- Check for working CXX compiler: C:/ming64gcc81/mingw64/bin/g++.exe --
 works
 -- Detecting CXX compiler ABI info
 -- Detecting CXX compiler ABI info - done
 -- Detecting CXX compile features
 -- Detecting CXX compile features - done
 -- Setting C++ requirement to C++11
 -- Setting GEOS version 3.7.0dev as port of JTS 1.13.0
 -- Setting GEOS C API version 1.11.0
 -- Setting GEOS build type - Debug
 -- Forcing IEEE 754 using flag -ffloat-store - ON
 -- Setting GEOS compilation with small functions inlining - NO
 -- Setting GEOS compilation with assert() macro enabled - OFF
 -- Looking for include file stdint.h
 -- Looking for include file stdint.h - found
 -- Looking for include file inttypes.h
 -- Looking for include file inttypes.h - found
 -- Looking for include file ieeefp.h
 -- Looking for include file ieeefp.h - found
 -- Looking for sys/types.h
 -- Looking for sys/types.h - found
 -- Looking for stddef.h
 -- Looking for stddef.h - found
 -- Check size of int64_t
 -- Check size of int64_t - done
 -- Performing Test HAVE_STD_ISFINITE
 -- Performing Test HAVE_STD_ISFINITE - Failed
 -- Looking for isfinite
 -- Looking for isfinite - not found
 -- Found Git: C:/ming64gcc81/msys/usr/bin/git.exe (found version "2.17.1")
 -- Generating GEOS
 C:/ming64gcc81/projects/geos/branches/build/geos_revision.h
 -- Generating GEOS
 C:/ming64gcc81/projects/geos/branches/build/include/geos/platform.h
 -- Generating GEOS
 C:/ming64gcc81/projects/geos/branches/build/include/geos/version.h
 -- Generating GEOS
 C:/ming64gcc81/projects/geos/branches/build/capi/geos_c.h
 -- Enable GEOS unit tests build - ON
 -- Enable GEOS XML tests build - ON
 -- Enable GEOS large geometry tests build - ON
 -- Enable GEOS performance tests build - ON
 -- CMake 3.7.2 successfully configured GEOS using MSYS Makefiles generator
 -- Configuring done
 -- Generating done
 CMake Warning:
   Manually-specified variables were not used by the project:
     HAVE_LONG_LONG_INT_64
 -- Build files have been written to:
 Scanning dependencies of target geos
 [  0%] Building CXX object src/CMakeFiles/geos.dir/algorithm/Angle.cpp.obj
 src/CMakeFiles/geos.dir/algorithm/BoundaryNodeRule.cpp.obj
 src/CMakeFiles/geos.dir/algorithm/CGAlgorithms.cpp.obj
 src/CMakeFiles/geos.dir/algorithm/Centroid.cpp.obj
 src/CMakeFiles/geos.dir/algorithm/CentroidArea.cpp.obj
 src/CMakeFiles/geos.dir/algorithm/CentroidLine.cpp.obj
 src/CMakeFiles/geos.dir/algorithm/CentroidPoint.cpp.obj
 [  1%] Building CXX object
 src/CMakeFiles/geos.dir/algorithm/ConvexHull.cpp.obj
 src/CMakeFiles/geos.dir/algorithm/HCoordinate.cpp.obj
 In file included from
 C:/ming64gcc81/projects/geos/branches/master/include/geos/geom/Coordinate.h:19,
                  from
 C:/ming64gcc81/projects/geos/branches/master/src/algorithm/HCoordinate.cpp:23:
 In static member function 'static void
 geos::algorithm::HCoordinate::intersection(const geos::geom::Coordinate&,
 const geos::geom::Coordinate&, const geos::geom::Coordinate&, const
 geos::geom::Coordinate&, geos::geom::Coordinate&)':
 C:/ming64gcc81/projects/geos/branches/build/include/geos/platform.h:70:23:
 error: 'finite' was not declared in this scope
  #    define FINITE(x) finite(x)
 C:/ming64gcc81/projects/geos/branches/master/src/algorithm/HCoordinate.cpp:74:9:
 note: in expansion of macro 'FINITE'
   if ( (!FINITE(xInt)) || (!FINITE(yInt)) )
 note: suggested alternative: 'finitef'
 In member function 'double geos::algorithm::HCoordinate::getX() const':
 C:/ming64gcc81/projects/geos/branches/master/src/algorithm/HCoordinate.cpp:151:8:
   if ( !FINITE(a) ) {
   if ( !FINITE(a) ) {
 In member function 'double geos::algorithm::HCoordinate::getY() const':
 C:/ming64gcc81/projects/geos/branches/master/src/algorithm/HCoordinate.cpp:162:8:
   if ( !FINITE(a) ) {
   if ( !FINITE(a) ) {
 make[2]: *** [src/CMakeFiles/geos.dir/build.make:264:
 src/CMakeFiles/geos.dir/algorithm/HCoordinate.cpp.obj] Error 1
 make[1]: *** [CMakeFiles/Makefile2:202: src/CMakeFiles/geos.dir/all] Error
 2
 make: *** [Makefile:139: all] Error 2
Ticket URL: <https://trac.osgeo.org/geos/ticket/914>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
