[geos-devel] [GEOS] #914: cmake compile under mingw64 gcc 8.1
geos-trac at osgeo.org
Fri Aug 17 18:01:45 PDT 2018
Reporter: robe | Owner: geos-devel@…
Type: defect | Status: new
Priority: major | Milestone: 3.7.0
Component: Build/Install (cmake) | Version: master
Severity: Significant | Resolution:
Keywords: mingw64 gcc 8.1 |
Comment (by robe):
Hmm but compiles on the svn-3.6 branch and all tests pass so must be
something we changed in 3.7
Checking out files: 100% (895/895), done.
Switched to branch 'svn-3.6'
Your branch is up to date with 'origin/svn-3.6'.
-- The C compiler identification is GNU 8.1.0
-- The CXX compiler identification is GNU 8.1.0
-- Check for working C compiler: C:/ming64gcc81/mingw64/bin/gcc.exe
-- Check for working C compiler: C:/ming64gcc81/mingw64/bin/gcc.exe --
works
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Detecting C compile features
-- Detecting C compile features - done
-- Check for working CXX compiler: C:/ming64gcc81/mingw64/bin/g++.exe
-- Check for working CXX compiler: C:/ming64gcc81/mingw64/bin/g++.exe --
works
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Detecting CXX compile features
-- Detecting CXX compile features - done
-- Setting GEOS version 3.6.4dev as port of JTS 1.13.0
-- Setting GEOS C API version 1.10.4
-- Setting GEOS build type - Debug
-- Forcing IEEE 754 using flag -ffloat-store - ON
-- Setting GEOS compilation with small functions inlining - NO
-- Setting GEOS compilation with assert() macro enabled - OFF
-- Looking for include file stdint.h
-- Looking for include file stdint.h - found
-- Looking for include file inttypes.h
-- Looking for include file inttypes.h - found
-- Looking for include file ieeefp.h
-- Looking for include file ieeefp.h - found
-- Looking for sys/types.h
-- Looking for sys/types.h - found
-- Looking for stddef.h
-- Looking for stddef.h - found
-- Check size of int64_t
-- Check size of int64_t - done
-- Performing Test HAVE_STD_ISFINITE
-- Performing Test HAVE_STD_ISFINITE - Failed
-- Looking for isfinite
-- Looking for isfinite - found
-- Generating GEOS
C:/ming64gcc81/projects/geos/branches/build/include/geos/platform.h
-- Generating GEOS
C:/ming64gcc81/projects/geos/branches/build/include/geos/version.h
-- Generating GEOS
C:/ming64gcc81/projects/geos/branches/build/capi/geos_c.h
-- Enable GEOS Unit Tests build - ON
-- Enable GEOS XML Tester build - ON
-- Enable GEOS large geometry tests build - ON
-- CMake 3.7.2 successfully configured GEOS using MSYS Makefiles generator
-- Configuring done
-- Generating done
-- Build files have been written to:
Scanning dependencies of target bug234
[100%] Building CXX object
tests/bigtest/CMakeFiles/bug234.dir/bug234.cpp.obj
[100%] Linking CXX executable ../../bin/bug234.exe
[100%] Built target bug234
Scanning dependencies of target TestSweepLineSpeed
tests/bigtest/CMakeFiles/TestSweepLineSpeed.dir/TestSweepLineSpeed.cpp.obj
tests/bigtest/CMakeFiles/TestSweepLineSpeed.dir/GeometryTestFactory.cpp.obj
[100%] Linking CXX executable ../../bin/TestSweepLineSpeed.exe
[100%] Built target TestSweepLineSpeed
Ticket URL: <https://trac.osgeo.org/geos/ticket/914#comment:1>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
