[geos-devel] [GEOS] #914: cmake compile under mingw64 gcc 8.1
GEOS geos-trac at osgeo.org
Fri Aug 17 18:04:03 PDT 2018
 Reporter:  robe                   |       Owner:  geos-devel@…
     Type:  defect                 |      Status:  new
 Priority:  major                  |   Milestone:  3.7.0
Component:  Build/Install (cmake)  |     Version:  master
 Severity:  Significant            |  Resolution:
 Keywords:  mingw64 gcc 8.1        |
Comment (by robe):
 first difference I see is in 3.7, it can't detect my isfinite function but
 in 3.6 it can.
 Other difference is in 3.7 we must have taken out this switch
  CMake Warning:
   Manually-specified variables were not used by the project:
     HAVE_LONG_LONG_INT_64
 cause I get the warning on 3.7 but not 3.6
Ticket URL: <https://trac.osgeo.org/geos/ticket/914#comment:2>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
