[geos-devel] [GEOS] #914: cmake compile under mingw64 gcc 8.1
geos-trac at osgeo.org
Fri Aug 17 19:10:07 PDT 2018
Reporter: robe | Owner: geos-devel@…
Type: defect | Status: new
Priority: major | Milestone: 3.7.0
Component: Build/Install (cmake) | Version: master
Severity: Significant | Resolution:
Keywords: mingw64 gcc 8.1 |
Comment (by robe):
Weird - well on winnie I see the same:
CMake Warning:
Manually-specified variables were not used by the project:
HAVE_LONG_LONG_INT_64
-- Looking for isfinite - not found
But she compiles fine.
If I take out the
https://git.osgeo.org/gitea/geos/geos/src/branch/master/CMakeLists.txt#L34
set(CMAKE_CXX_STANDARD 11)
set(CMAKE_CXX_STANDARD_REQUIRED ON)
gcc 8.1 mingw64 compiles and make checks fine. Not sure why those lines
are making it go crazy.
Ticket URL: <https://trac.osgeo.org/geos/ticket/914#comment:4>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
