[geos-devel] [GEOS] #914: cmake compile under mingw64 gcc 8.1
GEOS geos-trac at osgeo.org
Fri Aug 17 19:14:56 PDT 2018
 Reporter:  robe                   |       Owner:  geos-devel@…
     Type:  defect                 |      Status:  new
 Priority:  major                  |   Milestone:  3.7.0
Component:  Build/Install (cmake)  |     Version:  master
 Severity:  Significant            |  Resolution:
 Keywords:  mingw64 gcc 8.1        |
Comment (by cvvergara):
 Maybe because on C++11 cmath is standard, and then checking for isfinite
 on cmath is useless.
 Since C++11, isfinite shoud exist when using `include <cmath>`:
 https://en.cppreference.com/w/cpp/numeric/math/isfinite
 same applies to isnan
 https://en.cppreference.com/w/cpp/numeric/math/isnan
Ticket URL: <https://trac.osgeo.org/geos/ticket/914#comment:5>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
