[geos-devel] [GEOS] #914: cmake compile under mingw64 gcc 8.1
geos-trac at osgeo.org
Fri Aug 17 19:53:31 PDT 2018
Reporter: robe | Owner: geos-devel@…
Type: defect | Status: new
Priority: major | Milestone: 3.7.0
Component: Build/Install (cmake) | Version: master
Severity: Significant | Resolution:
Keywords: mingw64 gcc 8.1 |
Comment (by Regina Obe <lr@…>):
In [changeset:"195dba53b722ed250715f7690c6cafc69627e311/git" 195dba5/git]:
#!CommitTicketReference repository="git"
revision="195dba53b722ed250715f7690c6cafc69627e311"
Take out the C++11 enforcement causing issue with finite - see #914. Also
take out dev from pathc, its already in there
Ticket URL: <https://trac.osgeo.org/geos/ticket/914#comment:9>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
