[geos-devel] [GEOS] #914: cmake compile under mingw64 gcc 8.1
GEOS geos-trac at osgeo.org
Fri Aug 17 20:42:44 PDT 2018
 Reporter:  robe                   |       Owner:  geos-devel@…
     Type:  defect                 |      Status:  new
 Priority:  major                  |   Milestone:  3.7.0
Component:  Build/Install (cmake)  |     Version:  master
 Severity:  Significant            |  Resolution:
 Keywords:  mingw64 gcc 8.1        |
Comment (by robe):
 I tried vicky's patch
 https://git.osgeo.org/gitea/cvvergara/geos/commit/d2bc840dc20067cdf7cc2a7ef4c6cfb036b79548
 and that works too (and with keeping c+11 enforced).
 I'd rather not enforce until 3.8 which is when we had originally planned
 to enforce c+11.
 Though we may have code that requires it already I guess since I haven't
 tested on gcc 4.7.
 K'm going to close this out for now since issue is solved by 195dba5/git
Ticket URL: <https://trac.osgeo.org/geos/ticket/914#comment:10>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
