[geos-devel] [GEOS] #914: cmake compile under mingw64 gcc 8.1
geos-trac at osgeo.org
Fri Aug 17 20:43:43 PDT 2018
Reporter: robe | Owner: geos-devel@…
Type: defect | Status: closed
Priority: major | Milestone: 3.7.0
Component: Build/Install (cmake) | Version: master
Severity: Significant | Resolution: fixed
Keywords: mingw64 gcc 8.1 |
Changes (by robe):
* status: new => closed
* resolution: => fixed
Ticket URL: <https://trac.osgeo.org/geos/ticket/914#comment:11>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
