[geos-devel] [GEOS] #914: cmake compile under mingw64 gcc 8.1
GEOS geos-trac at osgeo.org
Sat Aug 18 20:32:37 PDT 2018
 Reporter:  robe                   |       Owner:  geos-devel@…
     Type:  defect                 |      Status:  reopened
 Priority:  major                  |   Milestone:  3.7.0
Component:  Build/Install (cmake)  |     Version:  master
 Severity:  Significant            |  Resolution:
 Keywords:  mingw64 gcc 8.1        |
Changes (by robe):
 * status:  closed => reopened
 * resolution:  fixed =>
Comment:
 unfortunately taking out the require c11 breaks travis and winnie, so I'll
 change to go with vicky's solution as it seems we really do require c11
 now.
Ticket URL: <https://trac.osgeo.org/geos/ticket/914#comment:12>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
