[geos-devel] [GEOS] #918: memory leak in GeometryCollection::getCoordinate()
GEOS geos-trac at osgeo.org
Tue Aug 21 07:13:09 PDT 2018
 Reporter:  basiliscos  |      Owner:  geos-devel@…
     Type:  defect      |     Status:  new
 Priority:  major       |  Milestone:
Component:  Default     |    Version:  3.6.2
 Severity:  Unassigned  |   Keywords:
 The implementation is
 const Coordinate*
 GeometryCollection::getCoordinate() const
         // should use auto_ptr here or return NULL or throw an exception !
         //      --strk;
         if (isEmpty()) return new Coordinate();
         return (*geometries)[0]->getCoordinate();
 So, if a collection is empty it returns coordinate and (to prevent memory
 leaks) assumes that caller should delete it. Otherwise it returns non-
 owning Coordinate* and not delete is required from caller.
 The best way is return NULL as it is told in the comment.
 The alternative will be
 static Coordinate zero;
 if (isEmpty()) return &zero;
Ticket URL: <https://trac.osgeo.org/geos/ticket/918>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
