[geos-devel] GEOS 3.7.0rc1 release
Greg Troxel
gdt at lexort.com
Mon Aug 27 17:06:32 PDT 2018
Not related to the maybe-clang/GeometryFactory test failure, I tried to
build on NetBSD/8 evbearmv7hf-el (RPI3, running 32 bit), and got
: tests/xmltester/test-suite.log
# TOTAL: 1
# PASS: 0
# SKIP: 0
# XFAIL: 0
# FAIL: 1
# XPASS: 0
# ERROR: 0
.. contents:: :depth: 2
FAIL: testrunner
terminate called after throwing an instance of 'geos::util::TopologyException'
what(): TopologyException: found non-noded intersection between LINESTRING (-105571 939969, -102895 939993) and LINESTRING (9485.36 770763, -102895 939993) at -102894.5562421389 939992.66927296668
[1] Abort trap (core dumped) ./XMLTester -v -...
FAIL testrunner (exit status: 134)
I believe this has normal IEEE754 floating point.
So I'm curious if anyone has run this on arm, and specifically armv7.
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geos-devel/attachments/20180827/d0c38f5d/attachment.sig>
