[geos-devel] GEOS 3.7.0rc1 release
Greg Troxel gdt at lexort.com
Mon Aug 27 13:24:04 PDT 2018
"Regina Obe" <lr at pcorp.us> writes:
> https://download.osgeo.org/geos/geos-3.7.0rc1.tar.bz2
Regarding
  https://trac.osgeo.org/geos/ticket/894
I don't see this on NetBSD/7 amd64, which uses gcc 4.8.
I did a build on macos 10.11, which uses clang (but a similar Intel
processor):
  Apple LLVM version 8.0.0 (clang-800.0.42.1)
  Target: x86_64-apple-darwin15.6.0
  Thread model: posix
  InstalledDir: /Library/Developer/CommandLineTools/usr/bin
and get the same failure as the bug.
Specifically, if I run test 1 in that group, it fails:
  $ ./geos_unit geos::geom::CoordinateArraySequenceFactory 1
    GEOS Test Suite Application
  geos::geom::CoordinateArraySequenceFactory: [1=F]
  ---> group: geos::geom::CoordinateArraySequenceFactory, test: test<1>
       problem: assertion failed
  tests summary: failures:1 ok:0
but tests 2,3,4,5 all pass.
The test is in tests/unit/capi/GEOSGeomFromWKBTest.cpp in the sources,
and is doing:
        // POINT(1.234 5.678)
        std::string wkt("POINT (1.234 5.678)");
        std::string wkb("01010000005839B4C876BEF33F83C0CAA145B61640");
        test_wkb(wkb, wkt);
I don't know how to get it to produce the mismatching content; the
--verbose option in --help is unrecognized, and I can't see how it would
be reading the driver source.
So I wonder if something in geos is sensitive to gcc/clang differences.
(Vastly less likely, there could be a clang bug.)
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geos-devel/attachments/20180827/d7263e48/attachment.sig>
