[geos-devel] GeometryPtr or ...
Daniel Baston dbaston at gmail.com
Fri Dec 7 06:40:31 PST 2018
I'd agree; I find that typedefs like GeometryPtr generally obfuscate
things. Although one can guess, it's not immediately obvious if GeometryPtr
means Geometry*, unique_ptr<Geometry>, shared_ptr<Geometry>, or something
else.
Dan
On Thu, Dec 6, 2018 at 5:46 PM Paul Ramsey <pramsey at cleverelephant.ca>
wrote:
> std::unique_ptr<Geometry> ?
> We've got a mishmash in the code base, what should it be?
> As a learner arriving at the code base, std::unique_ptr<Geometry> would
> have been easier, since then the semantics of the thing are more
> immediately transparent then. After working with it for a while, that's
> less of an issue because I've internalized the fact that GeometryPtr is a
> std::unique_ptr, but still.
> The best code styleguide is a consistent code base, so deciding and then
> globally changing makes the most sense, IMO.
> P.
> geos-devel mailing list
> geos-devel at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geos-devel
URL: <http://lists.osgeo.org/pipermail/geos-devel/attachments/20181207/3950e85a/attachment.html>
