[geos-devel] [GEOS] #853: Windows compile failing on 32/64bit with CMake: Could not find finite or isfinite function or macro!
geos-trac at osgeo.org
Tue Jan 16 00:14:00 PST 2018
Reporter: robe | Owner: geos-devel@…
Type: defect | Status: new
Priority: major | Milestone: 3.7.0
Component: Default | Version: master
Severity: Critical | Keywords:
Just noticed this, winnie's compiles started failing after these committs
sometime January 10th. Not sure which is at fault.
https://winnie.postgis.net:444/job/GEOS_Master/GCC_TYPE=gcc481,MAKE_TYPE=cmake,OS_BUILD=32/142/
Summary
removing -ansi and fPIC from C++ compilation (details)
getting stricter with warnings (details)
cmake: improving handling version (details)
Commit ed57b476690b07f1e8b51b015ec35ac6970aac7e by Sandro Santilli
The file was modified CMakeLists.txt
Commit 62380be288dc5cd2e6b5e8afc69e7b9e716546dc by Sandro Santilli
Commit d43e678578cfc60d02fbb051319d65e638474515 by Sandro Santilli
Note she builds using CMake. Transcript looks like this
-- The C compiler identification is GNU 4.8.3
-- The CXX compiler identification is GNU 4.8.3
-- Check for working C compiler: C:/ming64gcc48/mingw64/bin/gcc.exe
-- Check for working C compiler: C:/ming64gcc48/mingw64/bin/gcc.exe --
works
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Detecting C compile features
-- Detecting C compile features - done
-- Check for working CXX compiler: C:/ming64gcc48/mingw64/bin/g++.exe
-- Check for working CXX compiler: C:/ming64gcc48/mingw64/bin/g++.exe --
works
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Detecting CXX compile features
-- Detecting CXX compile features - done
-- Setting C++ requirement to C++11
-- Setting GEOS version 3.7.0dev as port of JTS 1.13.0
-- Setting GEOS C API version 1.11.0
-- Setting GEOS build type - Debug
-- Forcing IEEE 754 using flag -ffloat-store - ON
-- Setting GEOS compilation with small functions inlining - NO
-- Setting GEOS compilation with assert() macro enabled - OFF
-- Looking for include file stdint.h
-- Looking for include file stdint.h - found
-- Looking for include file inttypes.h
-- Looking for include file inttypes.h - found
-- Looking for include file ieeefp.h
-- Looking for include file ieeefp.h - not found
-- Looking for sys/types.h
-- Looking for sys/types.h - found
-- Looking for stddef.h
-- Looking for stddef.h - found
-- Check size of int64_t
-- Check size of int64_t - done
-- Performing Test HAVE_STD_ISFINITE
-- Performing Test HAVE_STD_ISFINITE - Failed
-- Looking for isfinite
-- Looking for isfinite - not found
-- Found Git: C:/ming64gcc48/msys/usr/bin/git.exe (found version "2.8.2")
-- Generating GEOS E:/jenkins/geos/branches/build64cmake/geos_revision.h
-- Generating GEOS
E:/jenkins/geos/branches/build64cmake/include/geos/platform.h
-- Generating GEOS
E:/jenkins/geos/branches/build64cmake/include/geos/version.h
-- Generating GEOS E:/jenkins/geos/branches/build64cmake/capi/geos_c.h
-- Enable GEOS unit tests build - ON
-- Enable GEOS XML tests build - ON
-- Enable GEOS large geometry tests build - ON
-- Enable GEOS performance tests build - ON
-- CMake 3.7.2 successfully configured GEOS using MSYS Makefiles generator
-- Configuring done
-- Generating done
-- Build files have been written to: E:/jenkins/geos/branches/build64cmake
[35m[1mScanning dependencies of target geos[0m
[ 0%] [32mBuilding CXX object
src/CMakeFiles/geos.dir/algorithm/Angle.cpp.obj[0m
In file included from
E:/jenkins/geos/branches/3.7cmake/include/geos/geom/Coordinate.h:19:0,
from
E:/jenkins/geos/branches/3.7cmake/src/algorithm/Angle.cpp:23:
E:/jenkins/geos/branches/build64cmake/include/geos/platform.h:155:3:
error: #error "Could not find finite or isfinite function or macro!"
# error "Could not find finite or isfinite function or macro!"
src/CMakeFiles/geos.dir/build.make:63: recipe for target
'src/CMakeFiles/geos.dir/algorithm/Angle.cpp.obj' failed
make[2]: *** [src/CMakeFiles/geos.dir/algorithm/Angle.cpp.obj] Error 1
CMakeFiles/Makefile2:201: recipe for target 'src/CMakeFiles/geos.dir/all'
failed
make[1]: *** [src/CMakeFiles/geos.dir/all] Error 2
Makefile:138: recipe for target 'all' failed
make: *** [all] Error 2
Ticket URL: <https://trac.osgeo.org/geos/ticket/853>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
