[geos-devel] [GEOS] #853: Windows compile failing on 32/64bit with CMake: Could not find finite or isfinite function or macro!
geos-trac at osgeo.org
Tue Jan 16 01:07:15 PST 2018
Reporter: robe | Owner: cvvergara
Type: defect | Status: new
Priority: major | Milestone: 3.7.0
Component: Default | Version: master
Severity: Critical | Resolution:
Keywords: |
Changes (by strk):
* cc: cvvergara (added)
* owner: geos-devel@… => cvvergara
Old description:
> Just noticed this, winnie's compiles started failing after these committs
> sometime January 10th. Not sure which is at fault.
> https://winnie.postgis.net:444/job/GEOS_Master/GCC_TYPE=gcc481,MAKE_TYPE=cmake,OS_BUILD=32/142/
> Summary
> removing -ansi and fPIC from C++ compilation (details)
> getting stricter with warnings (details)
> cmake: improving handling version (details)
> Commit ed57b476690b07f1e8b51b015ec35ac6970aac7e by Sandro Santilli
> The file was modified CMakeLists.txt
> Commit 62380be288dc5cd2e6b5e8afc69e7b9e716546dc by Sandro Santilli
> Commit d43e678578cfc60d02fbb051319d65e638474515 by Sandro Santilli
> Note she builds using CMake. Transcript looks like this
> -- The C compiler identification is GNU 4.8.3
> -- The CXX compiler identification is GNU 4.8.3
> -- Check for working C compiler: C:/ming64gcc48/mingw64/bin/gcc.exe
> -- Check for working C compiler: C:/ming64gcc48/mingw64/bin/gcc.exe --
> works
> -- Detecting C compiler ABI info
> -- Detecting C compiler ABI info - done
> -- Detecting C compile features
> -- Detecting C compile features - done
> -- Check for working CXX compiler: C:/ming64gcc48/mingw64/bin/g++.exe
> -- Check for working CXX compiler: C:/ming64gcc48/mingw64/bin/g++.exe --
> works
> -- Detecting CXX compiler ABI info
> -- Detecting CXX compiler ABI info - done
> -- Detecting CXX compile features
> -- Detecting CXX compile features - done
> -- Setting C++ requirement to C++11
> -- Setting GEOS version 3.7.0dev as port of JTS 1.13.0
> -- Setting GEOS C API version 1.11.0
> -- Setting GEOS build type - Debug
> -- Forcing IEEE 754 using flag -ffloat-store - ON
> -- Setting GEOS compilation with small functions inlining - NO
> -- Setting GEOS compilation with assert() macro enabled - OFF
> -- Looking for include file stdint.h
> -- Looking for include file stdint.h - found
> -- Looking for include file inttypes.h
> -- Looking for include file inttypes.h - found
> -- Looking for include file ieeefp.h
> -- Looking for include file ieeefp.h - not found
> -- Looking for sys/types.h
> -- Looking for sys/types.h - found
> -- Looking for stddef.h
> -- Looking for stddef.h - found
> -- Check size of int64_t
> -- Check size of int64_t - done
> -- Performing Test HAVE_STD_ISFINITE
> -- Performing Test HAVE_STD_ISFINITE - Failed
> -- Looking for isfinite
> -- Looking for isfinite - not found
> -- Found Git: C:/ming64gcc48/msys/usr/bin/git.exe (found version "2.8.2")
> -- Generating GEOS E:/jenkins/geos/branches/build64cmake/geos_revision.h
> -- Generating GEOS
> E:/jenkins/geos/branches/build64cmake/include/geos/platform.h
> -- Generating GEOS
> E:/jenkins/geos/branches/build64cmake/include/geos/version.h
> -- Generating GEOS E:/jenkins/geos/branches/build64cmake/capi/geos_c.h
> -- Enable GEOS unit tests build - ON
> -- Enable GEOS XML tests build - ON
> -- Enable GEOS large geometry tests build - ON
> -- Enable GEOS performance tests build - ON
> -- CMake 3.7.2 successfully configured GEOS using MSYS Makefiles
> generator
> -- Configuring done
> -- Generating done
> -- Build files have been written to:
> [35m[1mScanning dependencies of target geos[0m
> [ 0%] [32mBuilding CXX object
> src/CMakeFiles/geos.dir/algorithm/Angle.cpp.obj[0m
> In file included from
> E:/jenkins/geos/branches/3.7cmake/include/geos/geom/Coordinate.h:19:0,
> from
> E:/jenkins/geos/branches/3.7cmake/src/algorithm/Angle.cpp:23:
> E:/jenkins/geos/branches/build64cmake/include/geos/platform.h:155:3:
> error: #error "Could not find finite or isfinite function or macro!"
> # error "Could not find finite or isfinite function or macro!"
> src/CMakeFiles/geos.dir/build.make:63: recipe for target
> 'src/CMakeFiles/geos.dir/algorithm/Angle.cpp.obj' failed
> make[2]: *** [src/CMakeFiles/geos.dir/algorithm/Angle.cpp.obj] Error 1
> CMakeFiles/Makefile2:201: recipe for target 'src/CMakeFiles/geos.dir/all'
> failed
> make[1]: *** [src/CMakeFiles/geos.dir/all] Error 2
> Makefile:138: recipe for target 'all' failed
> make: *** [all] Error 2
New description:
Summary
works
works
-- Generating GEOS
-- Generating GEOS
-- CMake 3.7.2 successfully configured GEOS using MSYS Makefiles generator
-- Configuring done
-- Generating done
-- Build files have been written to: E:/jenkins/geos/branches/build64cmake
from
failed
Comment:
Commit author is actually Vicky, dunno why Jenkins doesn't show that. I
did accept/commit her patches though.
Vicki, can you look at this please ?
Ticket URL: <https://trac.osgeo.org/geos/ticket/853#comment:1>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
