[geos-devel] [GEOS] #896: Many (all?) GEOS operations do not preserve SRID
GEOS geos-trac at osgeo.org
Mon Jul 9 14:42:56 PDT 2018
 Reporter:  dbaston     |       Owner:  geos-devel@…
     Type:  defect      |      Status:  new
 Priority:  major       |   Milestone:  3.7.0
Component:  Default     |     Version:  3.6.2
 Severity:  Unassigned  |  Resolution:
 Keywords:              |
Comment (by strk):
 So it turns out Geometry#setSRID is supposed to be only used in
 exceptional cases, for backward compatibility:
 https://github.com/locationtech/jts/blob/master/modules/core/src/main/java/org/locationtech/jts/geom/Geometry.java#L264
 Rather, a user should indeed set the SRID in the factory, which we're not
 doing from C-API.
 Now that we DO have garbage-collected factories (for precision model) we
 might start doing something about SRID too. Sounds like a wider plan is
 needed though.
Ticket URL: <https://trac.osgeo.org/geos/ticket/896#comment:7>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
