[geos-devel] [GEOS] #896: Many (all?) GEOS operations do not preserve SRID
geos-trac at osgeo.org
Mon Jul 9 17:43:23 PDT 2018
Reporter: dbaston | Owner: geos-devel@…
Type: defect | Status: new
Priority: major | Milestone: 3.7.0
Component: Default | Version: 3.6.2
Severity: Unassigned | Resolution:
Keywords: |
Comment (by dbaston):
Hi strk, I probably expressed myself poorly. I don't think the C API
should modify the GeometryFactory.
Because it is not possible to manipulate a GeometryFactory in the C API, I
think that the C API should set the SRID of the output geometries (after
they are created) to match the SRID of the inputs.
I don't think we should try to retrofit GeometryFactories into the C API.
Ticket URL: <https://trac.osgeo.org/geos/ticket/896#comment:8>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
