[geos-devel] PSC Vote Add Vicky Vergara as GEOS committer
Regina Obe
lr at pcorp.us
Mon Jul 23 15:58:13 PDT 2018
I like Vicky's interpretation better :)
> -----Original Message-----
> From: geos-devel [mailto:geos-devel-bounces at lists.osgeo.org] On Behalf Of
> Paul Ramsey
> Sent: Monday, July 23, 2018 6:22 PM
> To: GEOS Development List <geos-devel at lists.osgeo.org>
> Subject: Re: [geos-devel] PSC Vote Add Vicky Vergara as GEOS committer
> WRT = with regard to
> On Mon, Jul 23, 2018 at 3:10 PM, Vicky Vergara <vicky at georepublic.de>
> wrote:
> > forgot to mention
> > I will certainly WRT (Work, Review and Test)
> > On Mon, Jul 23, 2018 at 1:09 PM, Paul Ramsey
> > <pramsey at cleverelephant.ca>
> > wrote:
> >> On Sun, Jul 22, 2018 at 2:13 PM, Vicky Vergara <vicky at georepublic.de>
> >> wrote:
> >> > I wanted to start with changing the for loops to range loops, and
> >> > chose PolygonizeGraph class as first C++ class where to do the changes.
> >> > but when I started doing that small change, I just couldn't stop
> >> > myself from using c++11 goodies on PolygonizeGraph.
> >> > Now the file does not look at all as the original (big smile) java
> >> > is not C++, so C++ does not need to look like java, now, in my
> >> > opinion, the code on PolygonizeGraph looks more like C++.
> >> > https://github.com/libgeos/geos/compare/master...cvvergara:Polygoni
> >> > zeGraph
> >> As Sandro noted, the more we drift from the Java the more "fun"
> >> porting changes will be.
> >> WRT your branch, the mixture of formatting with actual changes makes
> >> it hard to find the real work.
> >> Also, you're imposing your syntactical style rather than matching it,
> >> things like indentation, etc, etc.
> >> I understand the mental place you're coming from doing that, I come
> >> from that place too, but since everyone has different styles, can you
> >> stick to real changes, and we can all agree (?) on a post-commit
> >> formatter?
> >> P.
> >> _______________________________________________
> >> geos-devel mailing list
> >> https://lists.osgeo.org/mailman/listinfo/geos-devel
> > Georepublic UG (haftungsbeschr nkt)
> > Salzmannstra e 44,
> > 81739 M nchen, Germany
> > Vicky Vergara
> > Operations Research
> > eMail: vicky at georepublic.de
> > Web: https://georepublic.info
> > Tel: +49 (089) 4161 7698-1
> > Fax: +49 (089) 4161 7698-9
> > Commercial register: Amtsgericht M nchen, HRB 181428
> > CEO: Daniel Kastl
