[geos-devel] PSC Vote Add Vicky Vergara as GEOS committer
Paul Ramsey pramsey at cleverelephant.ca
Mon Jul 23 15:21:39 PDT 2018
WRT = with regard to
On Mon, Jul 23, 2018 at 3:10 PM, Vicky Vergara <vicky at georepublic.de> wrote:
> forgot to mention
> I will certainly WRT (Work, Review and Test)
> On Mon, Jul 23, 2018 at 1:09 PM, Paul Ramsey <pramsey at cleverelephant.ca>
> wrote:
>> On Sun, Jul 22, 2018 at 2:13 PM, Vicky Vergara <vicky at georepublic.de>
>> wrote:
>> > I wanted to start with changing the for loops to range loops, and chose
>> > PolygonizeGraph class as first C++ class where to do the changes.
>> > but when I started doing that small change, I just couldn't stop myself
>> > from
>> > using c++11 goodies on PolygonizeGraph.
>> > Now the file does not look at all as the original (big smile)
>> > java is not C++, so C++ does not need to look like java, now, in my
>> > opinion,
>> > the code on PolygonizeGraph looks more like C++.
>> > https://github.com/libgeos/geos/compare/master...cvvergara:PolygonizeGraph
>> As Sandro noted, the more we drift from the Java the more "fun"
>> porting changes will be.
>> WRT your branch, the mixture of formatting with actual changes makes
>> it hard to find the real work.
>> Also, you're imposing your syntactical style rather than matching it,
>> things like indentation, etc, etc.
>> I understand the mental place you're coming from doing that, I come
>> from that place too, but since everyone has different styles, can you
>> stick to real changes, and we can all agree (?) on a post-commit
>> formatter?
>> P.
>> geos-devel mailing list
>> geos-devel at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/geos-devel
> Georepublic UG (haftungsbeschränkt)
> Salzmannstraße 44,
> 81739 München, Germany
> Vicky Vergara
> Operations Research
> eMail: vicky at georepublic.de
> Web: https://georepublic.info
> Tel: +49 (089) 4161 7698-1
> Fax: +49 (089) 4161 7698-9
> Commercial register: Amtsgericht München, HRB 181428
> CEO: Daniel Kastl
