[geos-devel] [GEOS] #887: Remove pre-release suffix from library name (libgeos-3.7.0alpha.so -> libgeos-3.7.0.so)
geos-trac at osgeo.org
Thu Jun 14 04:30:56 PDT 2018
libgeos-3.7.0.so)
Reporter: Bas Couwenberg | Owner: geos-devel@…
Type: defect | Status: new
Priority: major | Milestone: 3.7.0
Component: Default | Version: master
Severity: Unassigned | Keywords:
The autotools build includes the pre-release suffix in the library
filename.
This has quite an impact on packaging, requiring a library package rename
for every pre-release, and NEW processing of that new package which causes
delays.
The attached patch strip the pre-release suffix from the library filename.
Ticket URL: <https://trac.osgeo.org/geos/ticket/887>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
