[geos-devel] [GEOS] #887: Remove pre-release suffix from library name (libgeos-3.7.0alpha.so -> libgeos-3.7.0.so)
GEOS geos-trac at osgeo.org
Thu Jun 14 04:31:06 PDT 2018
libgeos-3.7.0.so)
 Reporter:  Bas Couwenberg  |       Owner:  geos-devel@…
     Type:  defect          |      Status:  new
 Priority:  major           |   Milestone:  3.7.0
Component:  Default         |     Version:  master
 Severity:  Unassigned      |  Resolution:
 Keywords:                  |
Changes (by Bas Couwenberg):
 * Attachment "strip-pre-release-suffix.patch" added.
Ticket URL: <https://trac.osgeo.org/geos/ticket/887>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
