[geos-devel] [GEOS] #887: Remove pre-release suffix from library name (libgeos-3.7.0alpha.so -> libgeos-3.7.0.so)
GEOS geos-trac at osgeo.org
Thu Jun 14 23:34:35 PDT 2018
libgeos-3.7.0.so)
 Reporter:  Bas Couwenberg  |       Owner:  geos-devel@…
     Type:  defect          |      Status:  closed
 Priority:  major           |   Milestone:  3.7.0
Component:  Default         |     Version:  master
 Severity:  Unassigned      |  Resolution:  fixed
 Keywords:                  |
Comment (by robe):
 Might be my sed.
 When I tried:
 echo "3.7.0alpha" | sed -E 's/(alpha|beta|rc)[[0-9]]*(dev)?$//'
 I got this:
 3.7.0alpha
 I thought * too meant 0 or more, but seems to not be respecting the 0
 However this works:
 $ echo "3.7.0alpha" | sed -E 's/(alpha|beta|rc)[0-9]*(dev)?$//'
 Gives:
 3.7.0
 What's the purpose of the extra []?
 My sed version is: sed (GNU sed) 4.2.2
 I'd be happy to change it to if that works for you
Ticket URL: <https://trac.osgeo.org/geos/ticket/887#comment:6>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
