[geos-devel] [GEOS] #887: Remove pre-release suffix from library name (libgeos-3.7.0alpha.so -> libgeos-3.7.0.so)
geos-trac at osgeo.org
Thu Jun 14 23:43:47 PDT 2018
libgeos-3.7.0.so)
Reporter: Bas Couwenberg | Owner: geos-devel@…
Type: defect | Status: closed
Priority: major | Milestone: 3.7.0
Component: Default | Version: master
Severity: Unassigned | Resolution: fixed
Keywords: |
Comment (by robe):
You know just [[0-9]]? doesn't work for me either for
3.7.0alpha not sure why I thought it did.
Ticket URL: <https://trac.osgeo.org/geos/ticket/887#comment:7>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
