[geos-devel] [GEOS] #894: FreeBSD and MacOSX failures on 3.7.0 - group: geos::geom::CoordinateArraySequenceFactory, test: test<1> assertion failed
geos-trac at osgeo.org
Sun Oct 7 18:07:48 PDT 2018
Reporter: robe | Owner: geos-devel@…
Type: defect | Status: new
Priority: blocker | Milestone: 3.7.0
Component: Default | Version: master
Severity: Unassigned | Resolution:
Keywords: |
Comment (by robe):
I had taken this test out of 3.7 so I could have the bessie bots regress.
I still have it in master so that's why Bessies are still failing.
I spoke to Paul Ramsey about this in the code sprint, he said yah he gets
some error in the tests he just ignores cause it seemed unimportant. I
think it was this one. He's on MacOSX (and Greg said it fails for him on
MacOSX too).
For reminder this is the test why bessies are screaming red. I was going
to switch the bessies to CMAke anyway where this test I don't think exists
geos::triangulate::Delaunay: .........
geos::triangulate::Voronoi: .........
geos::triangulate::quadedge::QuadEdge: ...
geos::triangulate::quadedge::QuadEdgeSubdivision: ...
geos::triangulate::quadedge::Vertex: .
geos::util::UniqueCoordinateArrayFilter: .
---> group: geos::geom::CoordinateArraySequenceFactory, test: test<1>
problem: assertion failed
tests summary: failures:1 ok:1125
FAIL geos_unit (exit status: 1)
Ticket URL: <https://trac.osgeo.org/geos/ticket/894#comment:15>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
