[geos-devel] [GEOS] #894: FreeBSD and MacOSX failures on 3.7.0 - group: geos::geom::CoordinateArraySequenceFactory, test: test<1> assertion failed
GEOS geos-trac at osgeo.org
Mon Oct 8 07:20:29 PDT 2018
 Reporter:  robe        |       Owner:  geos-devel@…
     Type:  defect      |      Status:  new
 Priority:  blocker     |   Milestone:  3.7.0
Component:  Default     |     Version:  master
 Severity:  Unassigned  |  Resolution:
 Keywords:              |
Comment (by gdt):
 Given that autotools is the official build system, and cmake doesn't yet
 replicate the behavior, it seems that the buildbots should stay on
 autotools.
 (I also don't understand why the tests would be different based on build
 system.)
Ticket URL: <https://trac.osgeo.org/geos/ticket/894#comment:16>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
