[geos-devel] [GEOS] #894: FreeBSD and MacOSX failures on 3.7.0 - group: geos::geom::CoordinateArraySequenceFactory, test: test<1> assertion failed
GEOS geos-trac at osgeo.org
Mon Oct 8 08:46:43 PDT 2018
 Reporter:  robe        |       Owner:  geos-devel@…
     Type:  defect      |      Status:  new
 Priority:  blocker     |   Milestone:  3.7.0
Component:  Default     |     Version:  master
 Severity:  Unassigned  |  Resolution:
 Keywords:              |
Comment (by dbaston):
 My understanding is that they're both "official":
 https://trac.osgeo.org/geos/wiki/BuildingOnUnixWithCMake
 For this reason, the Travis buildbot builds using both build systems:
 https://travis-ci.com/libgeos/geos?branch=master
Ticket URL: <https://trac.osgeo.org/geos/ticket/894#comment:17>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
