[geos-devel] [GEOS] #936: fail with cmake -DGEOS_ENABLE_MACOSX_FRAMEWORK=ON
GEOS geos-trac at osgeo.org
Thu Oct 18 22:37:20 PDT 2018
 Reporter:  xzcvczx     |      Owner:  geos-devel@…
     Type:  defect      |     Status:  new
 Priority:  minor       |  Milestone:
Component:  Default     |    Version:  3.6.2
 Severity:  Unassigned  |   Keywords:
 if you run cmake with that option enabled there is the following error
 CMake Error at capi/CMakeLists.txt:45 (add_dependencies):
   Cannot add target-level dependencies to non-existent target "geos_c".
   The add_dependencies works for top-level logical targets created by the
   add_executable, add_library, or add_custom_target commands.  If you want
 to
   add file-level dependencies see the DEPENDS option of the
 add_custom_target
   and add_custom_command commands.
Ticket URL: <https://trac.osgeo.org/geos/ticket/936>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
