[geos-devel] [GEOS] #936: fail with cmake -DGEOS_ENABLE_MACOSX_FRAMEWORK=ON
GEOS geos-trac at osgeo.org
Sat Oct 20 04:30:36 PDT 2018
 Reporter:  xzcvczx                |       Owner:  geos-devel@…
     Type:  defect                 |      Status:  new
 Priority:  minor                  |   Milestone:
Component:  Build/Install (cmake)  |     Version:  3.6.2
 Severity:  Unassigned             |  Resolution:
 Keywords:                         |
Changes (by xzcvczx):
 * component:  Default => Build/Install (cmake)
Ticket URL: <https://trac.osgeo.org/geos/ticket/936#comment:1>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
