[geos-devel] [GEOS] #937: geos/.h files not available in framework Headers
GEOS geos-trac at osgeo.org
Sat Oct 20 08:36:24 PDT 2018
 Reporter:  xzcvczx                |       Owner:  geos-devel@…
     Type:  defect                 |      Status:  closed
 Priority:  minor                  |   Milestone:
Component:  Build/Install (cmake)  |     Version:  3.6.2
 Severity:  Unassigned             |  Resolution:  invalid
 Keywords:                         |
Comment (by robe):
 Hmm I wonder if it's some configuration in trac that it's showing the
 latest fork/branch commit and not what is in the master branch
 Line 56 from master repo reads this:
 https://git.osgeo.org/gitea/geos/geos/src/branch/master/src/CMakeLists.txt#L56
   install(CODE "execute_process(COMMAND ln -sfh ../../Headers
 \"${GEOS_FWDIR_VER}/unix/include/geos\")")
 and not what is in pull request and
 https://trac.osgeo.org/geos/browser/git/src/CMakeLists.txt
   install(CODE "execute_process(COMMAND ln -sf .
 \"${GEOS_FWDIR_VER}/Headers/geos\")")
Ticket URL: <https://trac.osgeo.org/geos/ticket/937#comment:6>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
