[geos-devel] [GEOS] #937: geos/.h files not available in framework Headers
GEOS geos-trac at osgeo.org
Sat Oct 20 09:07:59 PDT 2018
 Reporter:  xzcvczx                |       Owner:  geos-devel@…
     Type:  defect                 |      Status:  closed
 Priority:  minor                  |   Milestone:
Component:  Build/Install (cmake)  |     Version:  3.6.2
 Severity:  Unassigned             |  Resolution:  invalid
 Keywords:                         |
Comment (by kyngchaos):
 One more note: the "unix" folder is created when the
 GEOS_ENABLE_MACOSX_FRAMEWORK_UNIXCOMPAT option is used.
Ticket URL: <https://trac.osgeo.org/geos/ticket/937#comment:7>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
