[geos-devel] [GEOS] #937: geos/.h files not available in framework Headers
geos-trac at osgeo.org
Sat Oct 20 09:10:34 PDT 2018
Reporter: xzcvczx | Owner: geos-devel@…
Type: defect | Status: closed
Priority: minor | Milestone:
Component: Build/Install (cmake) | Version: 3.6.2
Severity: Unassigned | Resolution: invalid
Keywords: |
Comment (by xzcvczx):
i will claim to blame proj here, as it seems that iframework needs the
<framework/.h> otherwise it doesn't descend into the Framework and headers
as far as i can tell, if you know something which will make it work
without explicit -I/-isystem into Headers or unix feel free to correct me
Ticket URL: <https://trac.osgeo.org/geos/ticket/937#comment:8>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
