[geos-devel] [GEOS] #894: FreeBSD and MacOSX failures on 3.7.0 - group: geos::geom::CoordinateArraySequenceFactory, test: test<1> assertion failed
GEOS geos-trac at osgeo.org
Sun Sep 2 17:04:15 PDT 2018
 Reporter:  robe        |       Owner:  geos-devel@…
     Type:  defect      |      Status:  new
 Priority:  blocker     |   Milestone:  3.7.0
Component:  Default     |     Version:  master
 Severity:  Unassigned  |  Resolution:
 Keywords:              |
Comment (by Regina Obe <lr@…>):
 In [changeset:"db3e7a7350e29b96255e34295f8771dd3fb80eee/git" db3e7a7/git]:
 #!CommitTicketReference repository="git"
 revision="db3e7a7350e29b96255e34295f8771dd3fb80eee"
 Take out failing test on FreeBSD/macOS Clang. References #894
 Will revisit in 3.8
Ticket URL: <https://trac.osgeo.org/geos/ticket/894#comment:9>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
