[geos-devel] [GEOS] #894: FreeBSD and MacOSX failures on 3.7.0 - group: geos::geom::CoordinateArraySequenceFactory, test: test<1> assertion failed
geos-trac at osgeo.org
Sun Sep 2 19:16:01 PDT 2018
Reporter: robe | Owner: geos-devel@…
Type: defect | Status: new
Priority: blocker | Milestone: 3.7.0
Component: Default | Version: master
Severity: Unassigned | Resolution:
Keywords: |
Comment (by Regina Obe <lr@…>):
In [changeset:"34cdf0252cd9ffd202f68faf94908860f5762461/git" 34cdf02/git]:
#!CommitTicketReference repository="git"
revision="34cdf0252cd9ffd202f68faf94908860f5762461"
Take out failing test on FreeBSD/macOS Clang. References #894
Will revisit in 3.8
Ticket URL: <https://trac.osgeo.org/geos/ticket/894#comment:10>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
