[geos-devel] [GEOS] #894: FreeBSD and MacOSX failures on 3.7.0 - group: geos::geom::CoordinateArraySequenceFactory, test: test<1> assertion failed
geos-trac at osgeo.org
Sun Sep 2 20:05:37 PDT 2018
Reporter: robe | Owner: geos-devel@…
Type: defect | Status: new
Priority: blocker | Milestone: 3.7.0
Component: Default | Version: master
Severity: Unassigned | Resolution:
Keywords: |
Comment (by robe):
Well remarking out that test wasn't sufficient for a clean pass, I still
get an error here:
make: stopped in
/usr/home/jenkins/workspace/GEOS_Worker_Run/label/bessie/34cdf0252cd9ffd202f68faf9
[jenkins at bessie
/usr/home/jenkins/workspace/GEOS_Worker_Run/label/bessie/34cdf0252cd9ffd202f68faf94
908860f5762461]$ tail -n 10 tests/unit/test-suite.log
geos::triangulate::quadedge::QuadEdgeSubdivision: ...
geos::triangulate::quadedge::Vertex: .
geos::util::UniqueCoordinateArrayFilter: .
---> group: geos::geom::CoordinateArraySequenceFactory, test: test<1>
problem: assertion failed
tests summary: failures:1 ok:1120
FAIL geos_unit (exit status: 1)
oops and I thought I was committing to my fork, I must have my scripts
backward :(.
I'm going to revert back and just leave this as it was.
Ticket URL: <https://trac.osgeo.org/geos/ticket/894#comment:11>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
