[geos-devel] GEOS 3.7.0rc1 release
Greg Troxel gdt at lexort.com
Tue Sep 4 12:16:36 PDT 2018
Greg Troxel <gdt at lexort.com> writes:
> Not related to the maybe-clang/GeometryFactory test failure, I tried to
> build on NetBSD/8 evbearmv7hf-el (RPI3, running 32 bit), and got
>      : tests/xmltester/test-suite.log
>   # TOTAL: 1
>   # PASS:  0
>   # SKIP:  0
>   # XFAIL: 0
>   # FAIL:  1
>   # XPASS: 0
>   # ERROR: 0
>   .. contents:: :depth: 2
>   FAIL: testrunner
>   terminate called after throwing an instance of 'geos::util::TopologyException'
>     what():  TopologyException: found non-noded intersection between LINESTRING (-105571 939969, -102895 939993) and LINESTRING (9485.36 770763, -102895 939993) at -102894.5562421389 939992.66927296668
>   [1]   Abort trap (core dumped) ./XMLTester -v -...
>   FAIL testrunner (exit status: 134)
> I believe this has normal IEEE754 floating point.
> So I'm curious if anyone has run this on arm, and specifically armv7.
I'm still seeing this with rc2, still only on armv7.
