[geos-devel] GEOS 3.7.0rc1 release
Regina Obe lr at pcorp.us
Tue Sep 4 13:40:25 PDT 2018
> >   terminate called after throwing an instance of
> 'geos::util::TopologyException'
> >     what():  TopologyException: found non-noded intersection between
> LINESTRING (-105571 939969, -102895 939993) and LINESTRING (9485.36
> 770763, -102895 939993) at -102894.5562421389 939992.66927296668
> >   [1]   Abort trap (core dumped) ./XMLTester -v -...
> >   FAIL testrunner (exit status: 134)
> > I believe this has normal IEEE754 floating point.
> > So I'm curious if anyone has run this on arm, and specifically armv7.
> I'm still seeing this with rc2, still only on armv7.
[Regina Obe]
Wondering it's a new or old problem.
Does it work on GEOS 3.6.3 (granted I think we may have beefed up the tests
in 3.7.0, so a success in 3.6.3 doesn't automatically imply 3.6.3 is good).
A failure would be most interesting :)
