[geos-devel] GEOS 3.7.0rc1 release
Greg Troxel
gdt at lexort.com
Tue Sep 4 17:29:34 PDT 2018
I tried 3.6.2, and got the following test result.
Has anyone run the geos tests on arm under Linux?
(I think this issue should definitely not hold up the release.)
: tests/xmltester/test-suite.log
# TOTAL: 1
# PASS: 0
# SKIP: 0
# XFAIL: 0
# FAIL: 1
# XPASS: 0
# ERROR: 0
.. contents:: :depth: 2
FAIL: testrunner
terminate called after throwing an instance of 'geos::util::IllegalArgumentException'
what(): IllegalArgumentException: Exponent out of bounds
[1] Abort trap (core dumped) ./XMLTester -v -...
