[geos-devel] [GEOS] #923: Memory leak in GEOSNode
geos-trac at osgeo.org
Tue Sep 18 11:37:50 PDT 2018
Reporter: Algunenano | Owner: geos-devel@…
Type: defect | Status: new
Priority: major | Milestone: 3.7.0
Component: Default | Version: master
Severity: Significant | Resolution:
Keywords: |
Comment (by cvvergara):
I am trying to reproduce the problem.
- I had to install clang (I did not have it on my computer
- build:
mkdir bild
cd build
cmake ..
make -j 2 && ctest --output-on-failure
- the tests results
[100%] Built target test_geos_unit
Test project /home/vicky/potree/geos/vicky/build
Start 1: test_geos_unit
1/8 Test #1: test_geos_unit ................... Passed 0.38 sec
Start 2: test_xmltester
2/8 Test #2: test_xmltester ................... Passed 11.53 sec
Start 3: test_bug234
3/8 Test #3: test_bug234 ...................... Passed 0.00 sec
Start 4: test_sweep_line_speed
4/8 Test #4: test_sweep_line_speed ............ Passed 1.97 sec
Start 5: perf_class_sizes
5/8 Test #5: perf_class_sizes ................. Passed 0.00 sec
Start 6: perf_iterated_buffer
6/8 Test #6: perf_iterated_buffer ............. Passed 12.28 sec
Start 7: perf_rectangle_intersects
7/8 Test #7: perf_rectangle_intersects ........ Passed 0.63 sec
Start 8: perf_memleak_mp_prep
8/8 Test #8: perf_memleak_mp_prep ............. Passed 11.49 sec
100% tests passed, 0 tests failed out of 8
Total Test time (real) = 38.29 sec
- doing the install:
sudo make install
sudo updatedb
- finnaly I could execute:
$ clang -fsanitize=address geos_leak.c -lgeos_c -L/usr/lib
-I/usr/include/geos
$ ./a.out
./a.out: error while loading shared libraries: libgeos.so.3.8.0dev: cannot
open shared object file: No such file or directory
What am I missing?
Ticket URL: <https://trac.osgeo.org/geos/ticket/923#comment:2>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
