[geos-devel] [GEOS] #923: Memory leak in GEOSNode
GEOS geos-trac at osgeo.org
Tue Sep 18 13:54:06 PDT 2018
 Reporter:  Algunenano   |       Owner:  geos-devel@…
     Type:  defect       |      Status:  new
 Priority:  major        |   Milestone:  3.7.0
Component:  Default      |     Version:  master
 Severity:  Significant  |  Resolution:
 Keywords:               |
Comment (by Algunenano):
 You need to change the paths for your local environment (`-L/usr/lib
 -I/usr/include/geos` to, I guess, `-L. -I./include` or maybe
 `-L/usr/local/lib -I/usr/include/geos`).
 If you need it I could try to setup the dev environment tomorrow and
 create an step by step guide from there.
Ticket URL: <https://trac.osgeo.org/geos/ticket/923#comment:3>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
