[geos-devel] [GEOS] #923: Memory leak in GEOSNode
geos-trac at osgeo.org
Tue Sep 18 13:56:42 PDT 2018
Reporter: Algunenano | Owner: geos-devel@…
Type: defect | Status: new
Priority: major | Milestone: 3.7.0
Component: Default | Version: master
Severity: Significant | Resolution:
Keywords: |
Comment (by dbaston):
You should also be able to see the same leak when compiling with gcc using
the standard flags, by running the test executable through valgrind,
Ticket URL: <https://trac.osgeo.org/geos/ticket/923#comment:4>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
