[geos-devel] [GEOS] #923: Memory leak in GEOSNode
geos-trac at osgeo.org
Wed Sep 19 08:01:14 PDT 2018
Reporter: Algunenano | Owner: geos-devel@…
Type: defect | Status: new
Priority: major | Milestone: 3.7.0
Component: Default | Version: master
Severity: Significant | Resolution:
Keywords: |
Comment (by cvvergara):
@strk
Can you verify this:
From what I see:
The commits of the tag:
https://github.com/libgeos/geos/releases/tag/3.7.0
are listed here:
https://github.com/libgeos/geos/commits/673b993976709d2f72c35c4886327d6f2752fe48
As you can see there is no commit (from me) involving the shadows on 3.7.0
I made sure when merging to master that it was done after master was
changed to 3.8
On:
https://git.osgeo.org/gitea/geos/geos/pulls/44
cvvergara merged 1 commits from cvvergara/geos:fix-shadow into master 2
weeks ago.
The history of commits on master shows that the shadow PR was merged after
the commit labeled: "Flip master to 3.8 development" that was done one
month ago.
https://git.osgeo.org/gitea/geos/geos/commits/branch/master
So, if something is wrong because of the shadows "fixes", then my
conclusion is that the milestone for this issue is for 3.8.0-dev not for
3.7.0
@Algunenano
Can you please test if the problem happens on that commit on the following
commit: 673b993976709d2f72c35c4886327d6f2752fe48
(on the mean time I will try to understand your process)
Ticket URL: <https://trac.osgeo.org/geos/ticket/923#comment:10>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
