[geos-devel] [GEOS] #923: Memory leak in GEOSNode
    geos-trac at osgeo.org
    Wed Sep 19 08:25:14 PDT 2018
 Reporter:  Algunenano   |       Owner:  geos-devel@…
     Type:  defect       |      Status:  new
 Priority:  major        |   Milestone:  3.8.0
Component:  Default      |     Version:  master
 Severity:  Significant  |  Resolution:
 Keywords:               |
Changes (by Algunenano):
 * milestone:  3.7.0 => 3.8.0
Comment:
 > So, if something is wrong because of the shadows "fixes", then my
 conclusion is that the milestone for this issue is for 3.8.0-dev not for
 3.7.0
 Yes, this does not affect 3.7.0. My bad, I'll change the milestone.
 > @Algunenano Can you please test if the problem happens on the following
 commit: 673b993976709d2f72c35c4886327d6f2752fe48 (on the mean time I will
 try to understand your process)
 No it doesn't. It only affects master from
 e7adbc55a20633064d3af49f2662b17e5ca02e47 and after.
Ticket URL: <https://trac.osgeo.org/geos/ticket/923#comment:11>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
