[geos-devel] [GEOS] #923: Memory leak in GEOSNode
geos-trac at osgeo.org
Thu Sep 20 09:21:01 PDT 2018
Reporter: Algunenano | Owner: geos-devel@…
Type: defect | Status: new
Priority: major | Milestone: 3.8.0
Component: Default | Version: master
Severity: Significant | Resolution:
Keywords: |
Comment (by cvvergara):
@algun enano
can you make this tests
Can you try on 3.7.0 and on master:
test 1: add at the end of the script `finishGEOS();`
test 2: only have in the script `initGEOS(test_log, test_error);
finishGEOS();`
For me without finishGEOS I get
Memory checking results:
Potential Memory Leak - 4
and with finishGEOS
Potential Memory Leak - 3
Note that in valgrind the Potential Memory leak mean:
That "Memory was allocated and was not subsequently freed before the
program terminated."
Ticket URL: <https://trac.osgeo.org/geos/ticket/923#comment:14>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
