[geos-devel] [GEOS] #923: Memory leak in GEOSNode
GEOS geos-trac at osgeo.org
Thu Sep 20 09:34:49 PDT 2018
 Reporter:  Algunenano   |       Owner:  geos-devel@…
     Type:  defect       |      Status:  new
 Priority:  major        |   Milestone:  3.8.0
Component:  Default      |     Version:  master
 Severity:  Significant  |  Resolution:
 Keywords:               |
Comment (by Algunenano):
 Adding finishGeos() to the script:
 3.7.0:
 ==5574== Memcheck, a memory error detector
 ==5574== Copyright (C) 2002-2017, and GNU GPL'd, by Julian Seward et al.
 ==5574== Using Valgrind-3.14.0.GIT and LibVEX; rerun with -h for copyright
 info
 ==5574== Command: ./a.out
 ==5574==
 ==5574==
 ==5574== HEAP SUMMARY:
 ==5574==     in use at exit: 56 bytes in 2 blocks
 ==5574==   total heap usage: 65 allocs, 63 frees, 81,848 bytes allocated
 ==5574==
 ==5574== LEAK SUMMARY:
 ==5574==    definitely lost: 0 bytes in 0 blocks
 ==5574==    indirectly lost: 0 bytes in 0 blocks
 ==5574==      possibly lost: 0 bytes in 0 blocks
 ==5574==    still reachable: 56 bytes in 2 blocks
 ==5574==         suppressed: 0 bytes in 0 blocks
 ==5574== Reachable blocks (those to which a pointer was found) are not
 shown.
 ==5574== To see them, rerun with: --leak-check=full --show-leak-kinds=all
 ==5574==
 ==5574== For counts of detected and suppressed errors, rerun with: -v
 ==5574== ERROR SUMMARY: 0 errors from 0 contexts (suppressed: 0 from 0)
 Master:
 ==17645== Memcheck, a memory error detector
 ==17645== Copyright (C) 2002-2017, and GNU GPL'd, by Julian Seward et al.
 ==17645== Using Valgrind-3.14.0.GIT and LibVEX; rerun with -h for
 copyright info
 ==17645== Command: ./a.out
 ==17645==
 ==17645==
 ==17645== HEAP SUMMARY:
 ==17645==     in use at exit: 416 bytes in 10 blocks
 ==17645==   total heap usage: 65 allocs, 55 frees, 81,848 bytes allocated
 ==17645==
 ==17645== 360 (88 direct, 272 indirect) bytes in 1 blocks are definitely
 lost in loss record 10 of 10
 ==17645==    at 0x4837DEF: operator new(unsigned long)
 (vg_replace_malloc.c:334)
 ==17645==    by 0x4B854B3: geos::noding::(anonymous
 namespace)::SegmentStringExtractor::filter_ro(geos::geom::Geometry const*)
 (GeometryNoder.cpp:61)
 ==17645==    by 0x4B85372:
 geos::noding::GeometryNoder::extractSegmentStrings(geos::geom::Geometry
 const&, std::vector<geos::noding::SegmentString*,
 std::allocator<geos::noding::SegmentString*> >&) (GeometryNoder.cpp:157)
 ==17645==    by 0x4B8581B: geos::noding::GeometryNoder::getNoded()
 (GeometryNoder.cpp:123)
 ==17645==    by 0x4B859E5:
 geos::noding::GeometryNoder::node(geos::geom::Geometry const&)
 (GeometryNoder.cpp:80)
 ==17645==    by 0x4865497: GEOSNode_r (geos_ts_c.cpp:2450)
 ==17645==    by 0x109300: main (in /home/raul/dev/public/geos/a.out)
 ==17645==
 ==17645== LEAK SUMMARY:
 ==17645==    definitely lost: 88 bytes in 1 blocks
 ==17645==    indirectly lost: 272 bytes in 7 blocks
 ==17645==      possibly lost: 0 bytes in 0 blocks
 ==17645==    still reachable: 56 bytes in 2 blocks
 ==17645==         suppressed: 0 bytes in 0 blocks
 ==17645== Reachable blocks (those to which a pointer was found) are not
 shown.
 ==17645== To see them, rerun with: --leak-check=full --show-leak-kinds=all
 ==17645==
 ==17645== For counts of detected and suppressed errors, rerun with: -v
 ==17645== ERROR SUMMARY: 1 errors from 1 contexts (suppressed: 0 from 0)
 Only initGeos() and finishGeos() in the script:
 3.7.0:
 ==6083== Memcheck, a memory error detector
 ==6083== Copyright (C) 2002-2017, and GNU GPL'd, by Julian Seward et al.
 ==6083== Using Valgrind-3.14.0.GIT and LibVEX; rerun with -h for copyright
 info
 ==6083== Command: ./a.out
 ==6083==
 ==6083==
 ==6083== HEAP SUMMARY:
 ==6083==     in use at exit: 56 bytes in 2 blocks
 ==6083==   total heap usage: 10 allocs, 8 frees, 80,096 bytes allocated
 ==6083==
 ==6083== LEAK SUMMARY:
 ==6083==    definitely lost: 0 bytes in 0 blocks
 ==6083==    indirectly lost: 0 bytes in 0 blocks
 ==6083==      possibly lost: 0 bytes in 0 blocks
 ==6083==    still reachable: 56 bytes in 2 blocks
 ==6083==         suppressed: 0 bytes in 0 blocks
 ==6083== Reachable blocks (those to which a pointer was found) are not
 shown.
 ==6083== To see them, rerun with: --leak-check=full --show-leak-kinds=all
 ==6083==
 ==6083== For counts of detected and suppressed errors, rerun with: -v
 ==6083== ERROR SUMMARY: 0 errors from 0 contexts (suppressed: 0 from 0)
 Master:
 ==26299== Memcheck, a memory error detector
 ==26299== Copyright (C) 2002-2017, and GNU GPL'd, by Julian Seward et al.
 ==26299== Using Valgrind-3.14.0.GIT and LibVEX; rerun with -h for
 copyright info
 ==26299== Command: ./a.out
 ==26299==
 ==26299==
 ==26299== HEAP SUMMARY:
 ==26299==     in use at exit: 56 bytes in 2 blocks
 ==26299==   total heap usage: 10 allocs, 8 frees, 80,096 bytes allocated
 ==26299==
 ==26299== LEAK SUMMARY:
 ==26299==    definitely lost: 0 bytes in 0 blocks
 ==26299==    indirectly lost: 0 bytes in 0 blocks
 ==26299==      possibly lost: 0 bytes in 0 blocks
 ==26299==    still reachable: 56 bytes in 2 blocks
 ==26299==         suppressed: 0 bytes in 0 blocks
 ==26299== Reachable blocks (those to which a pointer was found) are not
 shown.
 ==26299== To see them, rerun with: --leak-check=full --show-leak-kinds=all
 ==26299==
 ==26299== For counts of detected and suppressed errors, rerun with: -v
 ==26299== ERROR SUMMARY: 0 errors from 0 contexts (suppressed: 0 from 0)
 The issue are not the still reachable blocks, they refer to the default
 geometry factory. The issue are the `indirectly lost` and `definitely
 lost` blocks when using `GEOSNode` in master.
Ticket URL: <https://trac.osgeo.org/geos/ticket/923#comment:15>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
