[geos-devel] Progress on #837 - TopologyException in UnaryUnion
Martin Davis mtnclimb at gmail.com
Tue Apr 16 08:06:41 PDT 2019
That's good to know, Darafei.   Can you provide a data example that we can
use for doing performance testing?
I'm not seeing that JTS buffer(0) is slower than union() on a random
triangulation.  So perhaps either your dataset has some different
characteristic, or possibly GEOS buffer has different performance
characteristics to JTS.
On Tue, Apr 16, 2019 at 5:27 AM Darafei "Komяpa" Praliaskouski <
me at komzpa.net> wrote:
> Hello,
>> Ultimately I think the ideal approach is going to be abandoning
>> CascadedUnion and switch to a full union algorithm (which will essentially
>> be the same as running buffer(0).  This should have very good performance.
>  We're using PostGIS's ST_Union to dissolve a clipped TIN into a polygon.
> Current ST_Union implementation handles this measurably faster than
> ST_Buffer(ST_Collect(geom),0). Please keep this case in mind.
> Darafei Praliaskouski
> Support me: http://patreon.com/komzpa
> geos-devel mailing list
> geos-devel at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geos-devel
URL: <http://lists.osgeo.org/pipermail/geos-devel/attachments/20190416/1f2afb98/attachment.html>
