[geos-devel] Progress on #837 - TopologyException in UnaryUnion
Darafei "Komяpa" Praliaskouski
me at komzpa.net
Tue Apr 16 05:26:58 PDT 2019
Hello,
> Ultimately I think the ideal approach is going to be abandoning
> CascadedUnion and switch to a full union algorithm (which will essentially
> be the same as running buffer(0). This should have very good performance.
We're using PostGIS's ST_Union to dissolve a clipped TIN into a polygon.
Current ST_Union implementation handles this measurably faster than
ST_Buffer(ST_Collect(geom),0). Please keep this case in mind.
Darafei Praliaskouski
Support me: http://patreon.com/komzpa
URL: <http://lists.osgeo.org/pipermail/geos-devel/attachments/20190416/efdaba02/attachment.html>
