[geos-devel] [GEOS] #982: Postgis ST_ConcaveHull Runtime GEOS Problem?
geos-trac at osgeo.org
Sun Aug 25 07:52:27 PDT 2019
Reporter: tsw | Owner: geos-devel@…
Type: defect | Status: reopened
Priority: major | Milestone:
Component: Default | Version: 3.7.0
Severity: Unassigned | Resolution:
Keywords: |
Comment (by tsw):
I've further tested this today and calls to public.ST_UnaryUnion in
ST_Concave hull don't make any difference as they are only applied to
polygon geometries, and in this case, lines are the problem.
HOWEVER, the ST_UnaryUnion call made at the end of _st_concavehull added
in response to issue 3638 is the source of this problem. If this is
commented out the query runs instantly. Not sure if there is another way
to address 3638, but this change causes the slowdown I document here.
Ticket URL: <https://trac.osgeo.org/geos/ticket/982#comment:6>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
