[geos-devel] [GEOS] #982: Postgis ST_ConcaveHull Runtime GEOS Problem?
GEOS geos-trac at osgeo.org
Sun Aug 25 05:22:35 PDT 2019
 Reporter:  tsw         |       Owner:  geos-devel@…
     Type:  defect      |      Status:  reopened
 Priority:  major       |   Milestone:
Component:  Default     |     Version:  3.7.0
 Severity:  Unassigned  |  Resolution:
 Keywords:              |
Comment (by dbaston):
 FWIW, if I run ST_ConcaveHull(geom, 0.99) using GEOS master against
 PostGIS trunk, the query takes forever. If I run it using GEOS master
 against the ST_ConcaveHull implementation from PostGIS 2.3.10 it completes
 instantly.
Ticket URL: <https://trac.osgeo.org/geos/ticket/982#comment:5>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
