[geos-devel] [GEOS] #982: Postgis ST_ConcaveHull Runtime GEOS Problem?
GEOS geos-trac at osgeo.org
Sun Aug 25 04:55:37 PDT 2019
 Reporter:  tsw         |       Owner:  geos-devel@…
     Type:  defect      |      Status:  reopened
 Priority:  major       |   Milestone:
Component:  Default     |     Version:  3.7.0
 Severity:  Unassigned  |  Resolution:
 Keywords:              |
Comment (by dbaston):
 @Komzpa, would be cool if you could help out by running this query on a
 single version of PostGIS with two different versions of GEOS to confirm
 the performance difference.
Ticket URL: <https://trac.osgeo.org/geos/ticket/982#comment:4>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
